Want to upgrade wheels/tires with no lift
View attachment 17909 View attachment 17910
Thanks for the setup!! Looks and fits great. I did have to trim one inch of the inside mud flap but that was it. But I did go with the KM2 mud terrain. Might be the slight difference. Also, the old TPMS went in without an issue. Worst case scenario you can pickup a couple rebuild kits for a few bucks if there is an issue.
Looks clean. I like the debadged black wheels on the grey. Welcome to the forum.
@ Mayday I just got the same truck and I love your wheels and tires this is the first truck i have ever owned so I am not sure how to go about buying new tires and I want to make sure they fit. What type of tires did you get and what size are they? Also would they fit the stock 16inch rims if they are wider than the stock tires that come on it?
Good day everyone, I'm new here. Just picked up a new SR5 double cab . I’m Not interested in a lift at this time but I am wanting to get some new wheels. Can a 18" rim with no other modifications? What size tire would be recommended. Thanks
Welcome to the forum!
265/65/18 is same as 265/70/17 so should be no issues with +30 to +10 offset 18 x 7.5 wheels
Are you planning on lifting and adding larger tires in the future?
Do you want stock stance or a wider look?
I’m not planning lifting in the future, I just want a wider look.
I’d look at 18x8 with 0 offset and put 265/65/18 tires on it. It’s going to stick out about 1” further than stock and be about 1” taller total. You might get rubbing on the front mud flaps if you have them, remove them. Shouldn’t be any other issues except a small ding on the MPG.
I have a stock 2018 TRD Off Road with 265/65/16 tires on now. I bought the TRD 17x7 matte black rims and would like to put on 275/70/17 BFG KO2's. Will those fit with no rubbing and no cutting without a lift? I'm sorry if I am asking in the wrong place, I'm new here.
