2018 trd off road 4x4 newb question
John dev
Is there anyone else have a problem with their 2018 tacos
Im about to get a new trd off road 4x4
But i have seen online about some of the tacos
Having an issue with the rpm going up high and shifting gears
(A/T )only im guessing
Pretty much all of them have this issue. There's a TSB for better programming and you can also get an aftermarket shift control box called the Shift Sense Pro.
Would they be able to fixed this problem at the dealership?
Im planning to get an extended warranty just to make sure
It’s not a deadline issue it’s just annoying. But the dealership should be able to perform the TSB upgrade before purchase.
The ECU learning also makes a difference with the turd gens.
Mud flaps slider side step is out of stock from the dealer
Need to bring it back when its in stock
Question about ceramic coats
Is that better than the paint protection coat from the dealership
