Tried changing the dome lights with led
The front is ok but the middle is moving around
Its lose i 5hink those led bought on ebay are generic
The middle dome is a little touchy. About all the LED replacement bulbs you’ll see are kind of an odd fit for the middle.
If you can keep a good connection, even if it’s a little off center, it’ll do fine.
Possibly take a conductive material and wedge it between the build and the connection point? Might not work but just thinking. My brain is tired.
Essentially that’s the problem with them. The LED bulbs are made a little oblong for the light. It takes some finesse to get it in there.
One side of it is like a spring so i pryed it moved it closer to one another
I figured the led then will be pinched in place
But it doesnt work
It doesnt turn on
Ill just leave it alone
I managed to change the front
But it doesnt work
It doesnt turn on
You may have the polarity reversed. Try flipping the bulb around with a good connection.
A lot of the time when LED replacement bulbs don’t want to work that’s the issue.
I had an older car and someone had soldered the bulb in. I was like WTF this thing won’t come out. Upon closer inspection I realized what they did. SMH
**** I just lived through 50 winters in New England and the roads were salted all winter and near salt air corrosion from the Ocean. No more winter time road salt at least!
We're you up here in Rustachusetts?now idont know what they are using but after they salt the roads you can here it eating your vehicle in the driveway .****s nasty
Ernst Toyota called me this afternoon.......recalled blower motor is in.......scheduled to replace it Monday afternoon!
