Biggest tires I could run?
Whats the biggest size of tires I could run with my leveling kit 3” in front 1” in back
Welcome to the forum.
What Tacoma do you have? Year and model? Stock rims? Aftermarket rims? Size of rims?
Largest with aftermarket rim:
285/75/16,
285/70/17,
285/65/18,
depending on what size rim you buy. With that size tire you’ll need an aftermarket rim with a 0 or -6 offset. 7-8.5” wide works well. You could use wheel spacers with the stock wheels but I don’t recommend wheel spacers.
Largest with stock wheels no wheel spacer even with a lift:
265/75/16,
265/70/17,
265/65/18,
What was the attachment in your original post? It didn’t load.
Tacoma 2014 wheels I have now are fuel assaults 20x12 -24 offset
I’m not sure how to get the image I posted to load it says I can’t view it.
Will post again.
33 x 12.5 -20 is a fairly common size and you'll probably rub a little but that's the biggest you'll want. 305/55R20 is a close metric size. With a 12" wide wheel you'll need to stay wide but don't want to go taller than 33".
Welcome to the forum!
P.S. - research the cab mount chop if you haven't already done that.
It will rub haha
