Max tire size on 2014 TRD Sport?
I'm at 2" lift with the same size tire as you picked up. All I've had to do is trim plastic, will do the cab mount chop eventually, maybe over the holidays, I get very minor rubbing though, only turned and tucked. My caster is also at 4
P.s.- #FRIENDSDON'TLETFRIENDSRUNSPACERS View attachment 21924
Thanks- those tires in the pic are 295/75/16’s? What’s up with spacers? Appreciate the insight
Best option is a good wheel offset to help clear everything.
Still grateful for answering my newb questions. The wheels that the tires came on are 16x7 with a 25mm offset - I like them and they are stock Tacoma wheels. If I did a 3”/1” lift and put 1.25” spacers on to add some turning room, do you think I’ll rub the wheel well?
Yes 295 is wide for these trucks. 285/75:16 will rub some with that set up.
Welcome to the forum.
@TacoKen got it.
You can fit 265/75/16 no lift,
275/70/16 1.5-2” lift +13 to 0 offset is best
you’ll need 2.5”+ lift to get the 285’s to fit up front. You’ll also want wheels that have a 0 or -6 offset for best fit. I wouldn’t go wider than 9” on the wheels. 7-8.5” is best.
How far would 285/75/16 with a 2.5inch lift and -6 offset stick out past the fenders? Thanks
