2018 inferno red TRD Sport- lift kit/ tires ?
Not very knowledgeable about lift kits , so what should I be looking to get or know about lift kits? Don’t plan to do any off road more just for looks and to be higher. Tires for this also would be helpful
Thinking a 3 in lift? Pros / cons Thanks
I triple what @whippersnapper mentioned. Piece of advice, they all say i am not going to offroad then you get that itch[emoji23]
@OR17TRD you loved your Revtek lift didn’t you?
I don’t know about loved. I will say that for what it was it handled well. I would recommend it if you have the off road with the bilstein 4600’s and you’re not extreme off-roading. It will make the ride stiff for the DD but allows you to fit the 285/75/16’s if that’s what you want. I didn’t have any issues with it.
Would I do it again? No, only because of the stiff ride. I’d want a better ride for the DD and the capability off road.
No have not decided yet. Still looking for the best option from all the input on here! Live outside the Cleveland Ohio area
This is the 2013 that I just traded in for the 2018 inferno red so I would like this type out of look I bought the 13 used IMG_1544044015.741159.jpgso I have no clue what type of lift was on it
What is the AAL? And with the 5100s & AAL What would be a price I would be paying to have somebody do all that appreciate all your help also thank you
You can usually find the OME coils, 5100’s and an AAL for around $1000 or less depending on how much you want to search the deals. @whippersnapper02 posted a link to a company that sales the 5100’s at a good price. Install should be about $250-400 depending on the shop and how much they charge per hour. You should be able to do it for around $1500 or less.
There’s this kit for $799 but it’s only 2”
https://www.bilsteinlifts.com/shop/...ith-eibach-coils-for-2016-2019-toyota-tacoma/
This one is $1291
https://www.bilsteinlifts.com/shop/toyota-tacoma/2-arb-ome-lift-kit-2016-toyota-tacoma/
This is what dealer is suggesting?
Below are the the required parts for the Tacoma 3"- 1" lift.
The representative from the company that we deal with called us back and was able to adjust the price to $1499 + tax.
It includes wheel alignment and will give you a free rental for the day.
And we will put it in writing that it will not affect your factory warranty.
05-Current Toyota Tacoma
Lift Height: 3 Inch front, 1 Inch rear
Front lift method: Strut Spacer
Rear lift method: Lift Blocks w/U-Bolts
Includes: All necessary hardware & instructions
Max Tire Size: 32x11.50 Inch
Wheel Diameter: 16 Inch and Larger
Wheel Width: 8 Inch to 9 Inch
Backspace: 4 Inch to 5 Inch
Requires wheel alignment after installation
Seems high in price?
Run! Run as fast from that as you can. Dealer lifts are garbage.
#FRIENDSDON'TLETFRIENDSRUNSPACERS
Use the little magnifying glass. There's great alternatives to blocks and spacers that are just as budget minded.
