Having troubke tapping into a fuse
detulio3
I bought footwell led strips and tried hooking it up to the fuse box with multiple fuses with the fuse tapper provided and the lights dont turn on with the ground and everything connected. Turn car on and off and everything. Nothing worked at all. Help!
What did you tap into? Also make sure you have the polarity correct because LEDs only work one way.
The leds work fine when they connected via cigarette lighter but when i try to hook the wires up to the fuse box they dont work. The fuse isnt polarity specific is it?
Yup got to have a ground look for the bolt on the side wall then positive to the fuse it should work fine just watch out if your pulling more amps than the fuse it will blow the fuse everytime you turn it on.[emoji106]
Sent from my SM-G892U using Taco Forum mobile app
Yes, I remember them being polarity specific. Use a voltmeter to check.
I had the ground in multiple spots. I am going to use a multimeter today to see which one i should tap into.
