Tried to read the fuse block under my dash so that I could make a chart showing what each fuse services, as there is no chart in my owners manual. Thoughtful of the designers to put it in such an easy to access place.
How in hell do you get the cover off?
You have to have a small flathead screw driver to get it off. It also uses those low profile micro fuses so you then need needle nose pliers to pull a fuse out. All of that plus the location and no room for add a fuse unless you leave it uncovered or get the mesocustoms cover really annoys me.
Thank you for the information. I just noticed your post today. I asked the dealer how to get the fuse cover off and was told by a 'mechanic' there that he didn't know. In other words, bring it in so that we can charge you $65/hour to remove it.
