Wheel spacers
Hey..why because I Wanted to have a different look + wider stance like you mention. Please Explain your bad experience or issues.
People just like to be negative about things. I know people that have run wheel spacers for years with no issues. The stance looks good now. Be happy with what you’ve done and ignore negative comments.
By increasing the offset of the wheel, you place more stress on the axle’s studs, and in a front axle application on the unit bearings (or spindles) and ball joints of the axle. You also increase the tire scrub radius, changing the way the vehicle handles and increasing the difficulty of slow-speed turning. Also, by adding wheel spacers you are adding more components, and the more components, the more potential for failure. Make sure to properly tighten and torque all of the spacers’ bolts and nuts. Yes, it's the least expensive way to get the look you want. Kind of like using a leveling kit with spacers VS correct lift kit with coilovers. My son has had several lifted trucks with wheel spacers. Bearings were the first thing to go. But the trucks looked very cool. Just my opinion and not being negative as someone said who doesn't even no me.
Putting anything on a truck that doesn’t come from the actual engineering and assembly of the vehicle puts more stress on all components. Asking people why they would do something like putting on wheel spacers or a lift on a 2wd truck is an easy answer...Because they want to and it’s their truck. No, I don’t “know” you but I do know that people do things to their trucks and share because they are excited to what they’ve done, so people asking why you would do something like that is negative and rude. It’s just like people telling others that they aren’t fans of the rims or tires someone has picked out. If you don’t like them, don’t comment or just say it looks good.
Looks good
#FRIENDSDON'TLETFRIENDSRUNSPACERS
While I support this in terms of lifts 100%, not being an engineer, I wonder what difference wheel spacers vs different offset rims makes.
I'll never run spacers due to all the drama, there must be something about them that are a problem I guess.... But again, think about the rim offset being thrown into the mix. Are either different in the whole geometry side?
I don't support these spacers but not so much because of the wheel bearing geometry thing, I think you're spot on. Same geometry no matter which approach you go about it. I don't think a reasonable backspacing and offset (such as 4.5" and 0) are enough to put extra strain on our 1 wheel bearing, now the Browheels that have most of the tire outside of the fender have to be tortuous.
I don't support wheel spacers because of a buddy that ended up replacing half of his studs over a 2.5-3 year period. Everytime he rotated he re-torqued, a couple of lug nuts were always a tad loose, the ones that weren't ended up popping one day. He decided when he changed all of those that he'd torque down the spacers with a small drop of Loctite on each stud, that worked until brake time, popped about half trying to get the rear drums off...
Granted this was a Cheby and human error could have been a factor and I know many people run them with no issues but witnissing the hassle that they caused a friend in addition to all the holes being wollered out in the spacers that I removed from my '10OR strayed me for life....
Oh, and Dad rung one off at the Christmas tree as soon as he let go of the transbrake, but that's apples and oranges. The lesson was still the same to me tho, should've sent them back and got the right backspacing! They were "high quality" spacers but the studs were junk....
Lmao, traction on the strip will QUICKLY find the weakest link.
So giving/sharing information makes me negative and rude? Profound statement.......
Math :confused:
I don’t recommend them because most people aren’t going to do the required maintenance on them and they become unsafe at that point. I don’t want to have my family on the road with drunks and wheel spacers :D
No, just seeing that you question this guy about why he would use spacer, and you question another guy on why he would ant to lift a 2wd. Maybe because they both want to do those things to their trucks. People talking down to people because of the types of lifts they choose to the rim/tire setup they have put on their truck is an a$$hole move. Maybe you weren’t trying to sound rude asking both guys why they would want to do those things, but it sure seems like it. Sorry if I’ve misinterpreted, but it just seems rude to me. Profound or not think before you ask why when people are just asking for advice on what kind of item to get or showing their new stuff off because they’re excited about it. Just my opinion!
66 Mustang, stroked 289, first set of Mickey Thompson 50s in town (that’ll tell ya how long ago this was) on Cragar SS. Spacers with chromemoly studs.
Roger on the retorque every week but no other problems.
So you put a 302 crank and rods in your 289? :D
Good running combo!
What’s a cragar SS . Lol just kidding buddy. I remember them but I’m a late 70s model
