Plastidip question
My hood has light hail damage will Plasti Dip fill it in if I paint the whole Hood
If the dents are too bad you may be able to pop them out with suction or a hairdryer and air duster. I’ve done this a few times and it works great.
Heat the area up with a hair dryer and then take air duster held upside down. The quick temperature change can pop it out.
If that doesn’t work try a local paintless dent repair guy. They are usually pretty reasonable.
Did you turn it into insurance?
Tape around your decal, make sure you leave and inch of room around your decal. Put around 6-8coats of plastidip. Use a toothpick and trace around your badge and then peel the plastidip off and your badge should stay plastidipped. Its actually easy.
