Rear Diff Fill/Drain Plugs
B-Man
Hey everyone! The OEM fill/drain plugs on the rear diff on my '17ORDC use a 24mm socket to remove/replace. Does anyone make the rear plugs like the front diff that use a 10mm hex? Is using a 10mm hex better/worse than using the 24mm socket? Pros? Cons?
Thanks!
Changing the fluids yesterday AM liked using the 10mm hex. One tool to do both the front and rear instead of the 10mm for the front and 24mm socket for the rear. Making things simpler.
Does the front one fit the rear one? Can you find the part number for it and swap it.
Does the front one for the rear one? Can you find the part number for it and swap it.
I don't know if the fronts will swap with the back........definitely not the drain plug in the front......way too big.......the fill plug for the front looks smaller too. Looked for fill/drain plugs for the rear with 10mm hex but did not find.
Hence this thread.
