Question about lifts
You already made a thread on this exact subject?
you get what you pay for. Spacers are the cheapest way to go, but the worst option
their ride sucks, and they introduce the risk of damaging shocks because they extend the shock length without adding any travel
if you're not going to offroad, and you're going purely for looks; and there's no way to save up more money, they'll be fine.
there's lots of people running spacers and are happy with them. However in terms of lift quality, there's a reason coilovers are $1400, to these spacers $250
If you want to lift the whole truck and level it out then get the 1-1.5 inch AAl for the rear. Also if you just want to level you can just get the front struts
"leveling" is just that, bringing the front of the truck up so that it is level with the rear; since all trucks come with a factory rake that has the rear 1.5"-2" higher than the front
"lifting" is where you add a lift component to the rear as well, so that instead of just bringing the front up a tad, you bring up the whole truck.
terminology aside, you gotta analyze what your budget is, and if you're going to wheel your truck
No, you will lift and level in one step. If you get the billy 5100s and set them at 2.5 in the front (highest setting) and then get a 1in rear AAl which I believe they have on their site (check my first link) then that should level your truck out and lift it at the same time.
That is correct, the set of four billies is 307bucks. You will want to choose the rear shocks rated for 0-1.5 inches of rear lift if you get the 1in AAl
The rear AAl is a "helper leaf" it is placed inside your existing leaf pack and will lift the rear of the truck, the shock is just sized to accommodate the extra inch of lift.
