Wiring fog lights in an SR model
ireik88
I am buying factory 3rd gen fog lights with bezel for my 2019. Where can I buy the wiring harness to wire them up? The factory? And is wiring them difficult?
If you purchase the OE fog lights then you must purchase the wiring and switch and this can be as much as 400 bucks for it all. best is to install some after markets from amazon and these will come with their own switch or you can wire them into your headlights . I bought the above myself just like spursnation2323 did and install them in about 30 minutes. I wired them into my head lights with a bypass when not needing them to the switch so i could turn them on and off. however the switch I received with the fog lights is green and bright but you can always use a different switch. The above work great from amazon and are very bright. Make sure you adjust them to point down or you will blind people when driving. ;)
