1st gen tacoma mods
0795toyotaco
I'm interested to see what mods other people have done to their first gen tacomas. I'm looking for more ideas for my 95! Post your pics!
It would really be nice if you said what you have done and gave the specifics, like tire brand and size, what did you use for your lift, etc,.
3in coil over lift with aal in rear, all pro front and rear bumpers rhino lined, bushwacker fender flares, plasti dipped wheels and grill, and 33x12.50 wild country mtx
Painted Grill
Hello all, Just wanted to share mod I did this past week. I painted my chromed plastic grill gloss black with Krylon. I sanded the grill with 320 grit until the grill had no luster anymore. Then, cleaned with thinner or turpentine and sprayed about 4 coats of krylon. Waited about 10-15 minutes between coats. Came out pretty good. I'm very happy with it. Best to everyone this holiday season
That looks really good, nice job.:thumbsup:
Diff breather mod (it's on the list)
CB (i have almost everything)
trim the front mud flaps (I took 3'' off)
Diff lock anytime (Only on TRD)
2 lo mod (only on ADD trucks)
heavy duty (marine grade) battery terminals for easy adding of electrical to the battery ($5 from wally world)
Grey wire MOD, diff breather MOD , OME 883#'s on 1st gen Tundra 5100's, custom built OMD 3" leafsprings, relocation of pass. side rear shock to match the driverside, under frame mounted Hella flood light, Kenwood VHF 2M radio (send & recieve for miles) Ivan Stewart TRD Tundra wheels, deckplate MOD, Famous Fabrication slides, custom built tube bumper for the front, old school KC dayliters with 1 big HID flood in the middle, push start button for ignition,
this is off the top of my head, sure theres more though....
I seem a tacoma like my black one above and I noticed the rear shocks pointed towards the center of the bed. Does anyone know who you do this? Would you need longer shocks?
All depends on how you set it up. Unless you're doing alot of wheeling or something I wouldn't think it is Necessary, but here's how it's set up on my 79' ImageUploadedByTaco Forum1387509723.369881.jpg the mounting point for the bottom isn't welded directly to the axle, but is on a bracket connected to the axle. So if you wanted to do it yes you would have to make new mounting points
Has anyone here put a powertrax no slip locker in their 1st gen? I'm wondering if its really that easy to install like the place says they are. I can't find any kind of instructions anywhere. Thanks for any help.
