Rims/Tires and Offset
What size rims and tires can I get without having to do any modifications and or worry about rubbing. And what offset do I need?
Stock rims 16x7
Stock Tires 245/75R/16
Thanks
stock size is 265/70R16, factory offset is +25mm. What are you trying to do?
a 245/55R20 will fit with a 0 offset
Hi I want to put custom wheels on Tacoma and possibly a bigger tire size, but do not want to have to CMC or lift the truck. I just want to buy wheels and tires and bolt them on. I want 17" wheels. Thanks
So stick to a 17x8 or narrower wheel, avoid negative offset, a 0 offset and and 265/70/17 should fit and not require a CMC, you may be able to go to a 255/75or80/17 without a CMC but it really is dependent on offset being closer to stock.
Thanks does a negative offset move the wheel further inside the wheel well?
Hey guys, I have a 2019 TRD OffRoad double cab.
I want to get al terrains, currently running stock 265 70 r16.
Can i get a 285 tire without cmc or a lift? If so, what would the offset be? I'm open to 16 or 17 inch tire
Do you plan on offloading? backing up while turning? the short answer is no.if you want a 33" tire go with a 255/85R16 and factory sized wheels and even then you will need to remove or change your mudflaps.
Haha gotcha. But wouldn't a 255 be less wide than the 265 currently?
These are tires I'm considering
Hancook DYNAPRO AT2 - SIZE: 265/65R17
Yokohama GEOLANDAR A/T G015 - SIZE: P265/65R17
GoodYear
WRANGLER TRAILRUNNER AT - SIZE: 265/65R17
GoodYear
Yes a 255 is narrow in comparison to a 265, by 10mm to be exact. A 265/65R17 is factory size for sport so if you're looking to upsize you may want to look at 265/70R17
20200308_170545_HDR~3.jpg I have 265/70/17 on Level 8 rims 9 x17 with -12 offset .they rubbed at full turn so i lifted 1.5 all around very happy .i did put my tundra wheels on when i first got it and they were 18 x 8.5 /.4.5 back space and 0 offset .w 285/60/18 kuhmo excsta .weirdly enough there was no rub at all.?
