2010 Toyota Tacoma
I created another since you can only upload a few pics. I will just host them from photobucket. Also I cannot upload pics from my pc. It worked yesterday but not anymore.
First I'll start with what I traded in to get my Taco:
2003 Ford Ranger 4wd 4.0 5 speed. Decent truck if it could keep from killing the slave cylinder. I traded in at 150K miles still running strong.
Gotta love losers that can't get a job
Now onto the good stuff. New Taco the day I got it
My quad barely fits
Banks Monster Exhaust
I ditched the Banks and went with a TRD exhaust
Wet Okole seat covers
Redline Tuning hood struts
Weathertech Digital Floor Liners
Custom damage mod(fixed)
Mag light mount in the driver's side storage area:
AVS Stepshield
Color matched grill with Grillcraft insert
Before:
After:
Tuffy locking bed storage box
LEDsolutions
interior replacement LEDs for the map lights and dome light.
^Click for his threads
Daytime installed pics:
Night pics. I tried to get all the same shots before and after. I have an issue with the dome light but it is getting replaced(thanks LJ). 6 out of the 24 LEDs on the dome are not as bright as the rest. I had to put on sun glasses to see what was going on. Each LED emits light from 3 spots. The 6 that are not as bright only emit light from one spot. So keep in mind that 6 LEDs in the dome are not at maximum brightness.
This is a white stage 2 kit:
Stock dome from driver's door
LED dome from driver's door
Stock dome from front
LED dome from front
Stock dome from rear
LED dome from rear
Stock dome from passenger through 20% tint
LED dome from passenger side through 20% tint
Stock dome
LED dome
Stock map lights
LED map lights
Front cabin with both stock map lights on
Front cabin with both LED map lights on
Driver area with driver map light on
Driver area with one LED map light on
Keep in mind that only 18 out of the 24 LEDs in the dome are at maximum brightness.
JP Metal Fab Tie Down Brackets
Pop N' Lock Tailgate Lock
265/75 Goodyear Duratracs
. They fit with no rubbing at all. I haven't been offroad yet so I don't know if they will rub at full compression. The trucks feels squirley so I did the chalk test. It looks like they were overinflated at 35 psi so I dropped them to stock pressure and I'll chalk them tomorrow. There is less road noise and just a bit of tire noise.
Out with the derp lower dash and in with the better lower dash.
Before:
After:
****ATRAC EQUIPPED TRUCKS**** The plugs for the ATRAC button and AUX port are the same except for the color. Make sure you match the colors correctly.
Breather mod
rcbs204 lighted 4wd switch
1.5-2" lift using Fox 2.5 extended travel resi shocks up front, Light Racing upper control arms, Fox 2.0 Resi shocks out back, Wheeler's Progressive 3 leaf AAL and Wheeler's Superbumps front and rear.
Light Racing arms swapped for Icon Tubular Uniball uppers
Rear
Bora .75" wheel spacers
Before:
After:
Brembo blank rotors and Hawk LTS pads.
Race Times:
I rolled into the throttle in 2wd with Auto LSD on:
1/8th mile 9.848 @ 70.53 mph
http://www.youtube.com/user/fddriver.../4/HcXIILBthPw
Second run I was in 2wd with Auto LSD on but I punched the throttle off of the line. The ALSD system worked a bit to get the truck going:
1/8th mile 9.960 @ 70.74
http://www.youtube.com/user/fddriver.../3/kDxpasWR0I4
This time I used 4wd and launched off of the converter:
1/8th mile 9.838 @ 67.62
Last run was 4wd and converter again:
1/8th mile 9.760 @ 70.44
Pioneer AVIC-8000NEX
Icom IC-V8000 HAM
Solo Motorsports 2" over LT kit
(needs shocks and various other parts before I do the install)
I like the okoles, man! Whole trucks looks very clean and i like how your going for the more practical mods first!
Re: Turdy :: 2010 Toyota Tacoma
Thanks. I used to drive a lot so I just wanted to make my truck a comfortable place to be in. Lift and junk can come later.
I probably would've been smarter and better off that way too since mine is my only vehicle, but i dont have very good discipline when it comes to such things i do want a set of those seat covers though.
Truck looks good man! I wish I could run that aggressive of a tire, damn my work commute.:censored:
Thanks.
I would commute 62 miles a day on these. I have about 40K miles on them without issue. They did have slight cupping issues but I don't know if that was an alignment issue or an air pressure issue.
