WHAT HAVE YOU DONE TO YOUR TACOMA TODAY?
I plasti dipped the Tacoma emblem on the tailgate yet it rubbed off because for some reason the emblem touches the bumper when the tail gate is down. Is there anyway to prevent this?
I have a stock bumper with my emblems dipped and it doesn't touch at all. Like Demo said it is prob because you have a after market installed.
Finally tackled something I have wanted to do for a while -- tie the dome light and map lights together so the map lights come on with the dome light when opening doors or turning the dome light to "on", but still work independently as well. It was a bit frustrating trying to unpin the OEM connector to reverse the leads, and then I couldn't find an appropriate connector pin to add the switched ground lead from the dome light and had to "modify" a weather-pack connector pin for the job. Once done -- nothing -- forgot that the polarization switch requires the LEDs be turned around to work. Had me scratching my head for a long time before I realized the simplistic problem that was kicking my butt. Anyway, can't wait until dark to see how big a difference it makes as everything is now working fine and the install looks factory, even though nobody is ever going to see the work itself...
Long day today working through the rains to get this new sealed auxiliary fuse/relay box wired and installed and all the current add-ons rewired. Lots of extra capacity pre-wired...
