Fog lights
I was looking at buying some fog lights for my Tacoma and was wondering where I should buy them at? Installing process? And if I wanted to put a different bulb in the light how would I go about doing that? Thanks
What model is your truck? You may have some wiring in the truck from the factory. Also I would skip the OEM light and go with an aftermarket kit from Rigid or Baja Designs.
I think the v6 did
Rodrigo must be golfing again and cant hears phone over the epic golfcart shenanigans
I was wondering the same thing? I have a 2009 Tacoma 4x4 Acess Cab (4 cyl 5sp MT). Looks like the truck pictured ans was thinking I could install fog lights w/o cutting into the factory wiring. Hoping Toyota or some other mfg. has a fog lamp kit that just plugs into the factory wiring??? I have not seen one to date??
My 2013 2.7 sr5 4x4 access cab isn't prewired.
Same truck.. just 09 Tacoma. I don't think mine is prewired. Can you get the switch, wiring harness and fogs from a salvage yard and adapt them to a truck without prewiring??
I guess you could if you wired it yourself
Found this vid on youtube. I'll have to check for wiring once the nasty weather up here in NE Pennsylvania stops (snow, sleet, ice and rain). Anyone see this on youtube??
The second part of this question would be.. Who makes a quality fog light kit??? Some of the ones I have seen "on line" look kinda cheap/ low quality.
I saw that video online. I was hoping mine would've been prewired like his but it wasn't. I bought a cheap set off eBay for 60 bucks. I sent it back because i could tell it was crap. My fault for trying to be cheap.
