Wheel spacers
I wanted to get some spacers for the ole taco and I don't know what size to get. I've heard the 1 1/4 are great but I want to try to get a more aggressive stance. I'm running 265/75 tires right now. If anyone has pictures of 1 1/4 spacers and 2" spacers that would be much appreciated. Also would it cause rubbing?
I wouldn't put spacers on. Get some lower offset wheels it won't cost that much more. -6 to -12 off set will push the tire out ~1.5"
I agree with OR17TRD, I would avoid the spacers and do wheels instead. It probably won't rub on regular turns, but it will a lil bit on those stressed out flexed turns (wheelin) I was runnin 265/75-16 on my 99 before the lift, and it didn't rub unless I was in the woods. Ball peen hammer inside the fender fixed that! [emoji6]
Had to use the hammer and cut some of the plastic in the front and will be adding a helper leaf in the back should take care of that rub as well
