285/75/16 ko2
egrau
Will I be able to mount 285/75/16 on my factory wheels with the spacer and a level kit on the front in my trd offroad 2016?
What brand of lifting kit do you recommend? I already have the spacer wheels mounted
I think it’s the best kit for the gen3 Tacoma off-road but yes it’s about $4000+ installed.
Cheaper lift would be the bilstein 5100’s front and rear, OME 887 coils, Dakar leaf pack and TC UCA. Around $2000. You could save money if you don’t replace the UCA and do an AAL in back instead of the Dakar leaf pack. Around $1200
it's very good. I will soon make the decision of which one I will assemble. here in PR is not worth much in which you invest money in a good suspension because there are not so many places to do good offroad
Yes but it will rub on the front a little so you will have to trim and make sure you get it aligned by someone who knows what there doing I have a 2011 Toyota Tacoma with 3inch left 285/75/18
If that’s the case you could put the revtek pro 40013 kit on it’s $420 and most shops will charge $200 to install it. It’s a spacer up front and an AAL in the back and utilizes the stock bilstein 4600’s. But know that for a few hundred dollars more you can do the bilstein 5100’s front and back and an AAL in the back and get a much better ride.
If I go by the 5100 and I can ride them myself and I know a lot about car mechanics and I have my own tools
Estimated cost about $400 for the 5100’s and $200 for the AAL will get you started. You can always add OME 887 coils, Dakar pack and UCA later if wanted.
Make sure you get an alignment after you install everything and get new wheels that are balanced.
i m in the same boat with you. I have 285/75/16 Mickey Thompson with fox suspension set, spidertrax 1.25 spacer oem rims. They rubs pretty obvious as of now. The manufacturing offering only 1.25 inch lifting front for me. I'll take them to auto shop and have them readjust the height to 2.75 or 3. I'll see what happen after.
