Rims&Tires
ScreaminYoda
Just bought the 2018 Toyota Tacoma Sr5 quicksand color. I was looking for suggestions on some beefier rims and tire sizes without a lift kit that would make it look a little more off-road ready. Any suggestions would be greatly appreciated.
Congrats on the new Tacoma. Biggest tire you’ll be able to fit without a lift is 265/75/16 or 265/70/17
Widest wheel I would go is 8” with that tire and would probably stick closer to the 16x7” stock size if you plan on wheeling and airing down your tires at all. The wider the wheel and narrower tire the weaker the tire bead is when aired down opposite is effective. You can get a lower offset wheel which will give a wider stance I wouldn’t go lower than -6 offset.
If you want bigger tires you’ll need to lift it.
thanks for the info. Appreciated
What about 285/70/17??
With a 3” lift and 0 or -6 offset wheels and a good alignment. Yes.
285 it’s going to be to wide.
285/75/16
285/70/17
285/65/18
285/60/19
285/55/20
They are all the same size.
