HELP! Hey Tacoma Friends! Snow in Wa!
Sounds like an actuator is not engaging fully. Does it speed up and slow down with your speed? Also can you still change your AC/Heat setting from floor, dash, combo, and defrost? It may sound weird but if there is no change in the vents it is likely that fluid leaked in to the vacuum system.
Interesting I will have to check it again thanks for the great info
The vent thing is just an easy way to check. I know it sounds weird but sometimes it works. Even if the vents work however, it may just mean that it hasn’t leaked much fluid.
And the best part of using the air horn is that your passenger side seat will be stained like that drivers seat your giving away because your passenger will crap their pants if you hit it in the cab. Lol.
Hahahahaha. Oh Bogunn! You got jokes!! An air horn would scare the next door neighbors
