Oil filter question
eagleguy
Does the 2017 Tacoma V6 have a spin on or cartridge type oil filter and where is it located? I did not see either when I took a quick look underneath but did I also did not crawl all the way under as I should have.
It's underneath in a housing attached to the engine. You need a special service tool to remove the housing cap. I'll look for pics.
img_5334-1024-jpg.798206
img_5296-1024-jpg.798207
You remove the center bolt and insert the plastic piece to drain the housing then the plastic housing is removed to access the filter element. Change those seals!
img_5324-1024-jpg.798208
Wrench (Many out there but this one looks like it grabs more of the housing:
https://www.amazon.com/gp/product/B...rd_t=36701&pf_rd_p=2079475242&pf_rd_i=desktop
I'm curious. I don't have a Tacoma yet, but what is the advantage to using a cartridge type oil filter versus a spin on type? Seems like a bunch more trouble to change your oil and filter. There must be a reason why Toyota went to the cartridge type. Any ideas?
Less oil waste.
EPA
