Morning yesterday i spent some time looking for the tailgate key for my 2016 but is is mia some i pulled the gate apart to find no undercoat anywhere WTF ! So i headaed to true value and picked up some cans of clear spray on sealer " As seen on TV " ! It worked awesome so im going to do the rest under neath as soon as i can pressure wash the chassis heres some pics
Morning yesterday i spent some time looking for the tailgate key for my 20a6 but is is mia some i pulled the gate apart to find no undercoat anywhere WTF ! So i headaed to true value and picked up some cans of clear spray on sealer " As seen on TV " ! It worked awesome so im going to do the rest under neath as soon as i can pressure wash the chassis heres some pics
Take pics of the chassis to when done [emoji41] I'm also looking for something to coat my frame with
No problem ! If you look under neath and up behind rear tires u will notice there is no under coating inside rear 1/4 panels as well . It will be when I'm done I will let you all know how many cans too. I'm going to use the clear .so I don't have black undercoat on everything .Thanx Stephen
Looks great! What is the head rack used for?
Typically used to protect the rear window from getting broke out. Allows you to put taller loads in without risk of damage or injury from objects flying through the window. You can also use it as a tie down point. Another reason I like my bakflip MX4 it has the same function when folded up all the way.
That’s another reason I’d have an MX4 if I didn’t already have the OEM.
Installed LED bed lighting for $12. Over 3’ of waterproof LED ribbon lights with a manual or automatic sensor that runs on AAA batteries. I leave the automatic on and it comes on when I open the tailgate. These pictures were taken in daylight. It’s definitely enough to light up the whole bed.
