Wheel offset on stock height 2017 Tacoma w/275/65R18
Tacotony75
Got a 2017 Limited Quicksand Tacoma and was wondering what the max offset wheel I could go without lifting the truck. I am running 275/65 18.
+30 offset if you’re going the other way. I didnt think that’s what you meant when you said max offset. I could be wrong though.
Well that’s a bummer haha. Most wheels are offered in either stock or -12 offset. So I might have to go down a tire size to fit the -12 offset
I should specify. The wheels I want are only offered in 1 and -12. And are 18x9
+1 offset in 9” with 275/65/18 would work but you might need 5100’s in front set to 0.75” to level the truck and help clear the tires better. You can try the -12 if you want to.
Let us know what you do and the outcome.
Don't know if this is the correct time or place, but... I kept 3 sets of new tires (275/65/18) from my 15 tundra due to a short sighted buyer, would like to make use of them on my new '18 tacoma trd off road (stock 265/70/16). If they'll fit OP's Limited, they should fit my truck. No? I do know new wheels will be in order. Thanks for any advice, could save me $$$.
Congrats on the new Tacoma. Welcome to the forum. You’ll need a 0 or -6 offset and an extra inch up front for added clearance. They should work with the right wheels.
