What rear diff fluid do you prefer?
  • Synthetic
    Votes: 7 87.5%
  • Dino
    Votes: 0 0.0%
  • Valvoline
    Votes: 0 0.0%
  • Mobil1
    Votes: 1 12.5%
  • Amsoil
    Votes: 3 37.5%
  • Supertech
    Votes: 0 0.0%
  • 75 90
    Votes: 6 75.0%
  • 75 140
    Votes: 0 0.0%
  • Royal purple
    Votes: 0 0.0%
  • Redline
    Votes: 1 12.5%
  • Total voters
    8
Im betting toyota doesnt make any fluid.... therefore i bet someone else makes 75 85
https://www.amazon.com/Toyota-Genuine-Fluid-08885-02506-Differential/dp/B004SL9HP6 I can get the Redline 75w85 gl5 for $16 a quart, probably should just use the 75w90 gl5 but im trying to stick with Toyotas recommendations on oils. I use the 75w85 in the rear diff only and use Walmart super tech 75w90 in the transfer and front diff this offsets the total cost a little for a 30k maintainence. since the trucks a daily driver I want the best MPGs so using the lighter oil in the rear might help some, if I towed or hauled heavy loads a lot I would use the 75w90 a little thicker oil.
Mobil 1 75-90 synthetic . no LSD additive as mine is an imposter..
I thought I saw a reference to this somewhere, but cannot find it (on mobile)... I'm trying to figure out what to use in my diff (Prerunner with electric locking diff). What exactly is an "imposter"?
I just used the word "imposter" because mine is not an actual limited slip. It is simulated by the rear brakes. I don't know much about the locking diffs and don't want to give you bad info. @whippersnapper02 has the Off road taco.
Thanks! I've been really spoiled with mine (Read: haven't had to touch it and therefore am ignorant), and am trying to get the lingo down!
2005-2008 offroads are not limited slip, no friction modifier additive needed
NO offroads are clutch type limited slip, only the 2009+ have brake actuated limited slip, no clutches... no need for friction modifier.
Trd sports from 2005-2008 have clutch type limited slips and need friction modifier added to gl5 and do not usually like synthetics from info gathered over the yrs. Mobil1 users thinking the "ls" tag on the bottle thinking that was good enough got chatter when doing tight turns. SOME said they had chatter with mobil1 with a tube of friction modifier. Easiest way to do this... use dino or semisyn, and friction modifier.
2009 to present offroad or sport or base dont have any clutch based limited slip, so no need for any friction modifier, use dino, syn, or semisyn.
