That little chrome section around your grill?
Kinda hard to remove. You have to pull the whole assembly off the truck and grind off the "melted" sections from the back. There's a few of them. And after that it should come off. Them you will need to plastic epoxy them back in after paint.
How do I remove it? Plain and simple I just want to paint it white and google is mo help
I'm guessing you wish to color match your grill. You paint it. Take 2 screws and 2 push pins on top out, pull grill straight up. There are 2 clips, 1 lower left & 1 right you have to squeeze to release, or just break them when you pull it. Like I did :laughing:, grill will still stay in place when you reinstall. Use painters tape to mask off center black. Or paint it like 1st gen Tundra's are. I'm getting ready to pull mine again for additional work and replacing with new lower clips. Cheap at dealer about $1.50 ea.
Hard to remove just the cover and reattach. Just mask it off or get yourself a parts geek grill. They come already separated, then you can paint and join the two pieces together.
I wish I could get a parts geek grill here to Hawaii..... Super cheap!
