Clueless
john e
Just bought a 2018 SR5 with the 16X7 rims i believe (stock?) And would like to have the "meaty" look, where the tire extends out past the wheelwell about 1".
Will a wider tire on the stock rim give me that look?
Thanks!
Thanks!
16x8 with a 4.5 backspace and 0 offset will do that for ya.
Backspacing/offset talk is basically forign language to me.
I just want a good looking truck where i dont want to lift it and dont have to worry about rubbibg at full turning radius.
I do. Im just not very familiar with this ****. Im old school.help me out then please!
The 1st 3 numbers are the width in mm
2nd numbers are the height of sidewall based on % of the width.... 65= tire will be 65% height of the tires tread width.
The 3rd number is rim diameter.
A 255 is narrower than a 265 for instance
A 265/75/16 is taller than a 265/70/16
That would be a 26x10 tire,... you might want to look at a 265/75R16.
...And no lift required or rubbing will occur?
265/75/16 will fit bone stock.... maybe minor rubbing on the worthless mudflaps when turned at full lock.... MAYBE.
