2018 Tacoma lift kits
View attachment 16976View attachment 16977View attachment 16978
HeadStrong’s has a Bilstein 5100 lift kit.
5100s all around set at zero
OME 887s
Light racing UCAs
Dakar’s in rear
1/4” spacer for lean
Stealth custom series SR8s 16x8
Fallen wildpeak AT3W 285/75/16
Got about 2.75” of lift and kept near stock rake which I like.
Nice!! Same color truck and model I have. Have been looking at your setup for a while, guess I need to pull the trigger and get it done.
Quick question? What Dakar's did you go with in the rear? I assume you got this kit from Headstrong.
It’s technically a “2” coil”. Most people with 3rd gen Tacoma’s are getting close to 3” of lift out of this set up when it’s done and you will be able to fit the 285/75/16 tires you want.
You can take the 887 coils and add bilstein 5100’s set to 0 and it will give you about 3” up front. The only problem with that is it can void the factory warranty of the OME coils and the Bilsteins when paired together.
If you purchase the set through Headstrong (and they build them), Headstrong will cover the manufacturer's warranty for them though.
I’m looking for a 3 inch lift
Alright. Lift this, lift that.
Here's the only lift you need to do. Everything else is window dressing
Following, I almost settled for junk country 4” lift, but after doing a lot of reading I might go this route as well.
