1999 Tacoma Old Man Emu 2.5 lift
bobthebuilderyc
Installed new lift not happy with rare higher than front. Not sure thats normal but want to level it out. Don't want to pull rear leaves. Is there a front coil spacer that will work with OME suspension?
No old man emu 2881coils front RA/RB 46 rear springs. 2" difference in height front to rear.
I have OME leaves as well, 2" front lift, and I sit about 1.5 higher in the rear. I don't mind it though since I'm always hauling stuff. They'll settle about a half inch after you abuse them off road for a couple of weeks. I suppose you could get a 1" leveling spacer for the front but I really don't recommend it on top of a 2.5 front lift. Definitely would need upper control arms if you don't already have them.
The Tacoma’s have a 1” rear rake to them from factory it’s normal. I like a rear rake. It evens out when loaded down with gear.
