2005 tacoma clutch master cylinder
fistofthejew
Hey everyone, my truck is difficult getting into gear...not bad but enough to piss me off. It also seems to slam into gear some times and slips/is jumpy when taking off in 1st gear, if that makes any sense. In the past 6 months I've replaced the clutch, slave cylinder and trans fluid and it's still an issue...I've purchased a clutch master cylinder and plan to install it this weekend. Any input on the matter would be helpful, thanks.
On the old yotas I have had, the clutch master cylinder was the only part I had to replace. Never the slave cylinder. Got a clutch master cylinder from OReilly's, it was the hardest to get adjusted. The ones from autozone worked fine. My first yota was an 88, later found a low mileage 91 that had AC! Got to be a big deal after I turned 50.
Sounds like the clutch master cylinder. Is the clutch pedal spongy feeling or sinking to the floor? If so that’s pretty well a definite from my experience.
