2006 catalytic converter P0430
Discussion in '2005 - 2015 Toyota Tacoma' started by SIGshooter, Jan 10, 2018.
  1. SIGshooter
    SIGshooter Member
    I got the P0430 code and was wondering if I deleted the catalytic converter will I cause any damage to my Taco?
    I don't have emissions where I live so that would be an issue, also will it affect the performance at all. Thanks guys.
  3. OR17TRD
    Are you sure that’s what it is? It looks like that code is somewhat generic. If you take the catalytic converter out you will still have the code?
    SIGshooter likes this.
  4. OR17TRD
    Could be your O2 sensor.
  5. OP
    SIGshooter
    SIGshooter Member
    I will have to check. I just got the code and was looking at options. I live in the middle of nowhere and its a 3 hours drive to the closest shop.
    OR17TRD likes this.
  6. Bojangles
    Bojangles Well-Known Member
    U want to do it right?
    Get long tube headers from urdusa.com
    Also there get the crush gaskets from urd
    And to shut that light off yet retain the check engine light function for OTHER later possible issues, get the urd 02 SIMULATOR.
  7. Bojangles
    Yes without an 02 sim
    OR17TRD likes this.
  8. Bojangles
    Dont forget u also have cats in the ypipe
  9. OR17TRD
    Figured you would know. Fritter exhaust.
    SIGshooter and Bojangles like this.
  10. OP
    SIGshooter
    SIGshooter Member
    Thanks guys, I will do some checking.
    OR17TRD and Bojangles like this.
  11. Bojangles
    Yeah the 02 sim connects to the rear cats. The rear 02 sim conditions the signal downstream of the front cats and tells the ecu "front cats working optimally" basically.
    SIGshooter and OR17TRD like this.
  12. Bojangles
    Something like that... im pretty tired and im running short tubes with cats.
  13. OP
    SIGshooter
    SIGshooter Member
    Hey Bojangles running the urd system what dose it do for performance?
  14. Bojangles
    What do u mean urd system?
    Urd makes/carries alot of items
  15. kp.taco
    kp.taco Well-Known Member
    Does cutting your cats off have any benefits?
    HP gains? Better MPG?
  16. Bojangles
    never seen dyno proof.
    IF they are falling apart and clogging the system........... YES
    otherwise, Ive yet to see any dyno proof of oem HEALTHY CATS themselves being a restriction. Words, yes..... but never anything objective.
    That said, going longtubes is proven to increase tq and hp. Thats due to the design of a header, as even short tube headers (with cats) can increase hp and tq.
    Bogunn, whippersnapper02 and kp.taco like this.
