2007 tacoma powersteering leak
PacoTheTaco
The leak is coming from the return line that meets the reservoir.
The clamp is not creating enough seal around the line so it’s leaking out around the edges and running down.
Should I replace the line ? The clamp? And what line is best ?
Thanks !
Thanks !
Kinda depends if it's the supply side (high pressure) or return side (low pressure). If it's the supply you'll probably need a new line, but if you can change the clamp try that first as whip said...
It’s the line on the right side, by the radiator.
I replaced the clamp and wiped everything clean that had powersteering fluid on it.
So hopefully that worked
