2008 Low Tire Indicator Light.....
Jeff W Waldrop
How to I get the light to go off. Reset?? Tires are all (5) properly inflated....
My oil change lube stop couldn't do it and I called the dealership and they weren't much help....
Jeff
Jeff
Bad or dead sensor, one of them probably needs replacement.
The batteries are not replaceable, and only last around a decade or less. Not sure if there is a way to disable the light, but it’s not really cost effective to replace them all unless you are already changing tires (and even then it’s pricey as hell).
sensors can be rebuilt by tire shops for around $10 each
you pressed and held the button under the dash to the left of the steering column already?
http://toyota.custhelp.com/app/answers/detail/a_id/7892/~/how-does-the-tire-pressure-monitoring-system-work-in-my-vehicle?
