2009 2.7 better clutch
Discussion in '2005 - 2015 Toyota Tacoma' started by Mag liter, Jun 5, 2018.
  1. Mag liter
    Mag liter Member
    I have been having very weird symptoms with my clutch, it does not feel right at all sometimes i will go to release it and it slips quite a bit then catches other times its moderately fine; it chatters quite a bit while slipping it. Clutch pedal has free play, im at 106k and i have not been happy with the clutch since i got it at 84k. I am looking to get a lce clutch or whatever else would work better than stock
  3. Bogunn
    Welcome to the forum. Sounds like it’s time to replace the clutch, pressure plate, and throw out bearing.
  4. OP
    Mag liter
    Mag liter Member
    Im torn between an lce pro or dual comp clutch kit, i have not looked at urd or the center force yet
  5. OP
    Mag liter
    Mag liter Member
    I ended up ordering an exedy/ daikin clutch kit, it also fits a 1993-4 t100 v6. By my thinking it will be a stronger clutch as the t100 had roughly 30 more horse power and could tow more. I will update the thread after i install it
    Bogunn and OR17TRD like this.
  6. OR17TRD
    Thanks.
  7. Bogunn
    Cool. Let us know how it goes.
  8. OP
    Mag liter
    Mag liter Member
    Install is on hold untill i figure out what toyota wants to do with my frame; if they replace it i will have the clutch put in then. But untill i figure out what they will do for me the install will have to wait
    OR17TRD and Bogunn like this.
  9. OR17TRD
    No need to replace it if they won’t do that.
