2013 transmission fluid
Discussion in 'Maintenance' started by filamb, Oct 7, 2017.
  1. filamb
    filamb Member
    I have 50k miles on my 2013. Just changed the oil myself. Pulled out of the driveway only to have my tranny slip in first gear. I can’t figure out how to check the fluid. Anyone know? Here I am sitting on the side of the road. Thanks
  3. whippersnapper02
  4. 4wd
    4wd Well-Known Member
    whippersnapper02 likes this.
  5. whippersnapper02
    o_O
  6. OR17TRD
    Don’t drain the transmission and add oil to the engine. You’ll be slipping gears and blowing seals.
    whippersnapper02, 4wd and Bogunn like this.
  7. whippersnapper02
    I still don’t get how anyone did this. It’s not a Previa so why would you think the pan is so far back?
    kp.taco and OR17TRD like this.
  8. OR17TRD
    Derp
  9. Bojangles
    Bojangles Well-Known Member
    1st gear meaning manual?
  10. OP
    filamb
    filamb Member
    It’s automatic. I had some “help” while changing my oil. I screwed up and drained 3.5 qts of tranny fluid instead. Dope!
    There was some good info posted to my original question. Thanks
  11. OR17TRD
  12. OR17TRD
    Did you get it all filled and running ok?
  13. OP
    filamb
    filamb Member
    Yes. No problems. But I had to go buy some tools. It was a somewhat expensive error. I’ve been taking care of maintenance on my cars for almost 40 yrs. That was a first.
  14. OP
    filamb
    filamb Member
    Ha. That’s what I did. Couldn’t figure out why I had so much oil in there. Thankfully I only drove 1 mile when I realized what I had done.
  15. OR17TRD
    The kind of thing you’ll only do once... hopefully.
    Bogunn likes this.
  16. OP
    filamb
    filamb Member
    Hopefully! My wife had invited friends over and I was a little distracted and in a hurry. And that darn tranny pan sticks out just begging to be drained. I drive a lot of miles. So it saves me a lot of time and money to do my own maintenance. 412k miles out of a 4Runner. Just got in a hurry. No excuses. Doesn’t appear to have done any harm. I’ve driven a few hundred miles on it since then. Pulling a trailer.
    TKFx and Bogunn like this.
