2016 Toyota Tacoma 2 inch lift kit
Assuming you are 2” front lift as well, DO NOT use lift blocks in the back. Add a leaf or purchase a 2” lift spring pack. Add a leaf will squeak a bit as the suspension flexes, a properly built new spring pack will not. Blocks torque the springs and will eventually fail, require constant retorquing of the bolts and cause much wear on the drivetrain. Add a leaf costs the same and required the same labor to install. IMO.
Thank you that's why I ask I will look in the getting the leaf springs and yes Blistin shocks all the way around and the 1.5 leaf for the back
