2017 taco level kit max tire size ?
265/75/16 or 265/70/17 with no rubbing with OEM wheels if you are leveling the front of the truck with the stock rear height. That changes if you are going higher all around.
If your leveling kit is more than 2.5" Whippersnapper02 is right on stock wheels. You can fit 285/75/16 if you get spacers, 1.25" spidertrax would work with your stock wheels. That's said I would never use spacers. I would get a lower offset wheel. Around 0 is good. -6 offset gives a good wider stance without looking silly.
It doesn't matter if it's 1", 2", 3" or anywhere between, if it takes the rake out its level. If a kit does that than it's a leveling kit.
Most people say something like 3 inch leveling kit which is not a leveling kit. It's like people that call the front coilover assembly a strut. The wrong terminology can change the answer.
