A solid leveling kit
I'm new to forums and figured I'd give this a shot. I have a 2010 Tacoma Double Cab short bed 4X4 TRD off road. I want to level it and put bigger tires on. After quite a bit of research this is what I've come up with. Bilstein 5100's all the way around, Total Chaos UCA, 1.5" add a leaf in the back, 1.5" wheel spacer with stock rims wrapped in 285/75/16. Does anyone else have this set up or something close to it? Where is the best place for prices? The best I've found was toytechlift.com. Any help and/or advice would be great.
Uppers are not needed for leveling. If you lift 3 inches then you need them. Check out Downsouth Motorsports. 285s will not fit unless you lift 3 inches and cut stuff.
Leveling kits raise the front of the truck so that it sits level with the stock rear. You want to lift the whole truck so you are looking for a lift kit. You said level kit so I said no uppers needed for a level kit.
I believe the Billys will give you the 3 inch lift you want in the front but I'm not 100% familiar with the lift they give.
Realistically I think they give you 2.5 upfront, I have them on my truck right now all the way around, as well as a 2in AAl. You won't need uppers.
No it won't hurt at all, actually it would benefit you, but I can assure you that you don't need them, your truck will be perfectly fine without them. But it would help if you got them.
