Acceleration hesitation
Discussion in '2005 - 2015 Toyota Tacoma' started by Taco Crews, Nov 8, 2019 at 10:45 AM.
  1. Taco Crews
    Taco Crews New Member
    I'm getting a hesitation on take off through my first few gears. Checked the plugs they look good. It's on a 06 Tacoma
  3. Will Evans
    Will Evans Well-Known Member
    Is it harder to start when hot? Could be compression.
    Is your air filter dirty?
    How about your fuel filter? I've heard these trucks are notorious for the fuel filter degrading and then clogging the system. Lets hope its not that.
  4. OP
    Taco Crews
    Only had it 3 weeks trying to figure out all it's issues. Gives me a place to start though. Thank you.
  5. Bojangles
    Bojangles Well-Known Member
    Replace plugs with oem denso coppers.
    Dump and replace fluids
    Fuel pump and filter are in the gas tank, leave that as a last resort imho.
    Replace air filter
    Remove negative battery wire for half an hour
    Clean maf sensor
    Clean throttle body
    Maybe u got crap gas?
    What do u mean plugs looked good?
    What was their gap?
    Scott Wyman likes this.
  6. OP
    Taco Crews
    Plugs where gaped at 35 I changed them to 44. There NGK was told they had just replaced them not to long ago. I was checking to see if maybe one was loose.its got 135000 miles and cold air intake. My next step was to start playing with the fuel system. To see if I can get it to smooth out.
  7. Bojangles
    Get a pic of the intake for me
    Is this a 4 cylinder or the v6?
    Those gap numbers dont sound right for the 4.0 v6......
    44 sounds off a little even
    U sure they are the CORRECT plugs?
    "Not long ago" means nothing in the world of used vehicles, esp in the 4.0 v6, those should be replaced at 30K.
  8. OP
    Taco Crews
    It is the V6. What's the best plugs for it? And at what gap should I run them? Intake looks clean. It idles perfect. Only get the hesitation when I accelerate from a from a stop. Acting like a vacuum issue.
  9. john morris
    john morris New Member
    I have '05 w/ 295K miles just started with acceleration hesitation. You mention clean "maf sensor and throttle body"? Can you elaborate? My mechanic skills are limited. Thanks!
  10. Will Evans
