Adding an amplifier
estruckman
Anyone know how or what to use to use an amplifier to power some aftermarket 6x9s in the doors of a 2012 tacoma? I have the entune without the jbl amp. Will better speakers sound better or will I need to use a small 2 channel amp? If so, how do I wire it up to back of the entune head unit?
You need a line output convertor wired into one of the speaker leads. Nothing can be done with the JBL system itself because it has a separate amp that uses a digital signal from the head unit. It would be best to replace the headunit as well if you want to upgrade.
Any aftermarket speaker sound sound better then stock I have the 6x9 from taco tunes and they sound 100 times better then stock no amp need on them
