The title is the code and message I received using the 'Fixd' app in conjunction with their OBD2 devise. The app also lists probable causes
for the code and how to repair. It said in 70% of the times this code is shown the problem was in the ABS wiring harness, so I pulled and found'
continuity was fine. I first unplugged it from the ABS speed sensor on the hub and check the plug on the battery side for volts with a multi-meter , key off and on positions for 0 volts. Then disconnected the top of the harness next to the fuse box in the engine compartment and checked the two pins in the top connector and got the same results. The app says the probability of the harness being the problem is 70%, the sensor being the problem is 20% and 10% chance it's a grounding strap on the sensor. I tested the two pin wiring harness for continuity and it seemed fine by it self. I just assumed I should get some voltage reading at the bottom of the harness if the top was connected. I need some help. I've never messed with this stuff and don't really know what I should buy so I would appreciate any comments
2015 Toyota Tacoma, double cab, V6, 4WD.
The wiring harness has a two pin connector on both ends
