I don't know this for a fact but I think the 75w85 that they recommend is either a conventional or synthetic blend. If anything the 75w90 will be better because more film strength when hot. I wouldn't do the 75w140, I'd be afraid that'd be too thick.What do you think about using 75w-90 instead of 75w-85 that Toyota calls for?
He probably just changes differentials and transmissions instead.there is a guy with a 96 taco in Virginia that has 400k + miles and claims to have NEVER changed the rear or front diff fluid, transfer or the MT fluid. never.
four hundred thousand miles
I've seen the differential internals of a chevy truck that the fluids were never changed in 150k miles. The bearings were just about ready to fall apart with the gear teeth razor thin.he claims that he has not in 26 years, all original still. but if he had to then all the good money spent on fluid servicing over this span would more than cover it!
also he operated a chain of autoparts stores so he says he knows a little something about it
