Gears and locker
cohick13
I have a 2010 Tacoma 4.0 auto 4x4 sr5 looking to get 4:10 gears and a locker what does everyone recommend
What size tires are you running or plan on running?
You might be able to find some factory 4.10 gears out of a 2.7L 4WD Access Cab and Single cab Manual and Auto's have 4.10 ratio's. Check wrecking yards?
I’d look at doing front and rear lockers if you’re going to be opening up the diffs anyways.
Also look into 4.56 gears if your plan on going 33-35” tires and have more weight with RTT, bumpers, winches, gear etc.
