Help
shawnerb34
I have a 97 Tacoma with the 2.7l I can roll start it but I can't start it with the key it will just turn over until the batterie dies I put a new fuel filter on it new plugs n wires I don't know what is wrong some help would be nice thanks
Plugs are good the first two wires go,to a box and the second two go to a box right next to it I checked all the connections and there good
Something else you might want to check for is a vacuum hose that may have popped off when you were changing the plugs. My '82 had a 22R in it and I would do just that and it ran really bad, that is until I put the hose back where it belonged.
Also, check your choke it could be stuck.
