How to complete turn of traction control on 2017 tacoma
How to turn traction control completely off even tho it says off it’s not off I even held down button when stopped and in neutral it still activates it when you spin tires
ALSD light off and TRAC OFF light and VSC light on? No need for neutral. Toyota's systems still lurk even when "off" but their intervention can be minimized if you are in the correct mode. The only way to truly disable is to lock the rear end, which requires 4wd low unless modified, or disable the ABS system.
What exactly are you experiencing? No spin at all or spin then no spin after a shift?
Cluster should have both lights on per the manual:
I know this is an old topic but mine activates when trying to spin donuts in this past weekends snow I cut traction control off but still sounds like its kicking on in the front end is there any way to cut it off?
