I bought this truck with a burnt vavle on number one I replaced the head with a reman ran fine for a month and then began my struggle so the problem is a semi rough idle when dead cold and miss fires bucks and overall runs like **** under 1/4 -3/4 throttle runs fine under full throttle and sometimes even when fully warm the idle will dip down low to 600 esh at a stop then perk back up if you blip the throttle even when warm from a dead idle you can hear and feel a hick up.
It idles fine and starts fine when hot starting but still runs like **** under load 1/4-3/4 throttle
1998 trd 2.7l five speed
So far replaced
New head
Injectors
Coils
Plugs
Cam position sensor
Maf
Both temp sensor ( the plug was destroyed and hooked up backwards for a bit. Idk if that ****s em up)
Throttle position sensor
Water pump
Thermostat
Fuel filter
The truck has no codes
Mechanical inclined please help Ive run out of ideas all done in the last five months
So far replaced
New head
Injectors
Coils
Plugs
Cam position sensor
Maf
Water pump
Thermostat
Fuel filter
