LED bulbs
Jimmy Gambill
Hey y’all what’s the best LED bulbs for headlights, brake lights, turning signals and license plate lights and cab roof top light for a 2019 SR5?
I know nothing about led's. Is it as simple as just changing the bulbs or do you need to do something with the wireing too, a blast or something like that?
Depending in what buld your replacing there could be polarity issues. If it doesn't light you may have to flip it around in the socket to get correct polarity. If it's on a flasher you may need to put a resistor in parallel to the bulb to keep from getting a code for burnt out lamp or get hyper blink.
I installed LASFIT led headlights and fog lights. They just plug in and you are done. $31 for the low beams. The best part are the switchback fogs. You flash the brights and the fog lights switch between bright clear and amber. They also have a hazard flashing mode $79 for the fogs.
