Lift kits question
Technically yes but do the spindle lift and save for a better coilover lift. Don’t buy junk country.
Keep in mind that spindle lifts are for prerunners.
Will i have any problems if I combine them. I bought the lifted shock instead of spacers. I wanna go higher
So the way it works is the spindle moves the wheel down but keeps the suspension in the same spot. You will be fine combining them but remember that coil preload will make your ride harsh.
Don't waste your $ on a spacer lift/blocks unless you only troll mall parking lots. They're completely useless for flex. Spacers will lift you an inch and you loose an inch of spring. The ride sucks ****. You can do a complete suspension lift on a prerunner for less than a thousand bucks, uca's will maximize the potential of a suspension lift, and make the ride smoother. Uca's aren't totally necessary, but they do add to the cool factor! [emoji47]
