Maintenance Required Light
SuttonBoynton
I have a 2006 standard taco and I was out in some cinders going pretty hard and this light came on. I believe it's the coolant but I'm not sure but can't take it into the shop. Any ideas? IMG_20190310_173306_952.jpeg
It's to remind you to change the oil. Comes on every 5k miles
So is there a way for me to turn it off? I to red looking up a video and doing the reset on it but it didn't work.
Owner's manual procedure (05-11):
Select ODO with the key off. Push and hold the ODO button and turn the key to on (don't start). It will count down dashes (----) and flash 0's. You're done.
Or change yer oil every 4999 & 9/10ths mile ? This should eliminate that troublesome light...:p
